TwinTurbo.NET: Nissan 300ZX forum - is your ambient air temp sensor plugged in?
aliaZ
on September 04, 2013 at 6:06 PM
TTZ air conditioner problem, compressor will not run
posted by MachinistZ
on August 31, 2013 at 05:35 PM
if the sensor on your bumper came unplugged your AC will stop working.
MachinistZ
17:35:29 08/31/13
is that the only thing that doesn't work?
Medallion Man
03:23:31 09/01/13
Re: is that the only thing that doesn't work?
MachinistZ
11:19:44 09/02/13
So I assume you've run 12v to the compressor with the
zellamay
19:48:18 09/02/13
Re: So I assume you've run 12v to the compressor with the
MachinistZ
22:01:00 09/02/13
For the second time .... does the compressor produce cold
zellamay
12:36:00 09/03/13
MachinistZ
22:43:49 09/03/13
Luck is the biggest factor there is. (n/m)
zellamay
09:11:48 09/04/13
Pin 46 is the ECU output for the A/C signal have you checked
SMAZ (OKC)
11:06:51 09/08/13
is your ambient air temp sensor plugged in? -
aliaZ
18:06:56 09/04/13
